Parts interchange??
Parts interchange??
I have a 40 and 420. The 40 is more of a basket case and I keep thinking it may get parted out. It really depends on what I find when I tear down the engine. It's sat outside for years (previous owner).
Is the hyd pump and PTO the same on a 40 and 420?? 40 has both and 420 does not.
What other parts will interchange??
The pump will bolt up and work but is smaller and uses a different suction line, tank and valve. PTO is different, 40 crawler had kind of it's own PTO.
Rollers are the same, front idlers might be, finals might be if the 40 had newer finals put on it in later years. If you have an all green 420, the transmissions will be the same too.
- Davie Sprocket
Great post all the way around, you guys are so helpful.
There are Heavy Equipment Parts and there are Heavy Equipment Parts... either way construction equipment breaks.
- Davie Sprocket
I have a 420 with 4 bolt pads and a 40 with 2 bolt pads. I even have some pads that look to be 6 bolts or a generic pad, might be that someone used 4 bolt pads and drilled them to fit the 2 bolt.
Are the 4 bolt pads for 420 and later or is there 420's with 2 bolt pads?
Just curious in my quest to find a set of pads.
Have a happy and safe Christmas.
Dave
Dave
4 bolt pads came out with the 1010/2010, the two cylinder crawlers did not use 4 bolt pads. 1010/early 2010 rails are the same pitch and bushings size as 420-440 and became the replacement rail in later years, or someone has put a used set on the crawler at some time. I can get you new 4 bolt pads, 2 bolt pads are Deere only, or may be obsolete at this point.
Users browsing this forum: No registered users and 108 guests
