A couple of questions , before ordering parts.
Since I want to get the parts for the broken final drive on my 420 , I have been reading the service manual . I understand the procedure for all of the rebuild . What I have been wondering about is the tool (page 145-15-3 pn AM2774T in the service manual) for installing the seal and retainer on the Axle . Is this tool available or do I need to have one made or is there another way to install the seal so the sealing lips poit in the correct direction . ? I checked JDparts but the part number comes back invalid . I will be starting on this project once I get the parts in . Dan
1956 420C with GSC blade
Tool #AM2774T
Dan,
I have a sketch that I drew up showing the dimensions for this special tool. I borrowed the tool from a JD friend and made the sketch so when and if I ever get the time I will make my own. If you are interested, I could scan the sketch and email it to you.
Best regards,
Best regards,
JAJ , I would be interested in the sketch , I will pm you with my email addy .
Bill , I have a machinist that can turn it out for me but , if JAJ will send you the sketch , work up a price including shipping to 16335 and give me a PM on it . I miss having access to a lathe since I got out of the tool and die trade years ago . Thanks guys for the information . Dan
- DiggerLarry
- Contact:
Jim , Got the email and thanks for the info. Really need to get a lathe for the shop .
Bill , I have priced materials for them and was thinking of making it from Polypropylene rod , I can get a 4" diameter X 12" long piece for $53 . Now if I can get a hold of my machinist to do the work . A 12" length would make two sets . Would still like you to figure it out and give me a price . PM when you have it figured out . Dan
Seems like the way to go if you're going to do this out of PVC is to get a length of 2.5" Schedule 80 pipe rather than starting with a bar. The dimensions of the Sch. 80 is ID of 2.29" and OD 2.875". Schedule 80 2.5" pipe looks to sell in the $5 per foot range. It's a little small for the knurled grip of the tool from Jim's dimensions but you could easily glue on the grip cut from a piece of a 2.5" coupling.
I'm going to make one up for Jim and let him evaluate the prototype. I'm guessing I can turn these out of PVC for about $30 each and out of steel for about $50 each. If you were only going to use it occasionally, the PVC looks like it would work fine. That being said, the wall thickness is only .045" with the insert removed so if the thing is going to see much service, steel might be the better way to go.
I'll post pictures when I get the prototype done.
I finally managed to got to talk to my friend that does my machining today , and he has time to do the job so I will order the material for it tomorrow . Dan .
Users browsing this forum: No registered users and 110 guests
