Track cross reference
- ptrachte
- Contact:
Hi all,
I've been reading many posts about which undercarriage parts go with which crawler, and a while back, Lavoy did a great summary of it. So being the geek that i am, i tried to make a cross reference that could be used to quickly figure out what parts will work on different rigs. (hopefully)
Here is what I came up with. I tried to be as faithful to Lavoy's original text as possible. I could use all your help in validating this table and sending me corrections.
the way it works is you pick the desired model from the left side, as the "donor", and a model from the top of the table for the recipient. then you look where the two models meet and that should be the "parts in common". Again let me know where i might have got it wrong, and i'll correct it and when its all accurate, we can post it to the site as a reference. On the other hand if its too confusticating, i'll just drop it.
Paul-1010 crawler/loader
- Eric.MacLeod
- Eric.MacLeod
now it's gone again
it doesn't show up again... maybe make a link to it
Re: now it's gone again
still not showing up,pop pop wrote:it doesn't show up again... maybe make a link to it
I think the link to the offsite host has been broken- Ptrachte would have to fix it.
Hi Paul-
The best way would be to use a thir-party picture sharing site like photobucket. I have instructions on how to do so within the "Messageboard and Announcements" forum.
- ptrachte
- Contact:
Here is a link i believe will be more permanent. Sorry for the inconvenience and delay.
Paul
http://users.upwardaccess.com/trachte/c ... m3m2_1.htm
Paul
Hi Paul-
It is great that you took the initiative to get the table back up for us- no worry about the delay.
One comment you may want to add to the table- while the pin/bushing diameter and links are the same for the 1010s and the early 2010s, the 1010s used fewer overall links on each side than the 2010s.
Users browsing this forum: No registered users and 56 guests
