MC engine swap
tbird505
MC engine swap
Post by tbird505 » Wed Feb 08, 2006 7:10 pm
Does anyone know if a420 engine would bolt into an MC without modification?
Post by Lavoy » Wed Feb 08, 2006 7:49 pm
It will bolt in, yes. You will need to fabricate a throttle shaft, change radiators, all throttle linkages and mounts, carb, air cleaner, and probably some other assorted parts that I am not thinking of.
When done, you will have a cobbled up crawler of little value, and if you are using it, it will only be a short time before the extra power of a 420 enigne will begin to destroy some real expensive parts.
M engines are readily availabe as are overhaul parts for an existing engine.
tbird505
Post by tbird505 » Mon Feb 13, 2006 3:20 pm
Sounds like you wouldn't reccomend it.
Post by Lavoy » Mon Feb 13, 2006 8:09 pm
Too much headache to install it, and too much potential to damge to the weaker drivetrain, especially when M engine are plenttiful and/or easy to fix.
Users browsing this forum: No registered users and 106 guests
