JD 440ICD Crawler Transmission / Differential Pinion Bearing
D.Light
Post by D.Light » Wed Nov 18, 2009 9:09 pm
I have been trying to help my Dad with a JD 440ICD Crawler. The Pinion Gear does not make good contact with the carrier in the Differential and therefore the crawler will not ... crawl. :(
Someone has already been working on this crawler and I suspect some parts are wrong and/or missing.... The pinion bearing outside diameter seems to be too small to fit the larger diameter slot in the transmission housing.
Is there a spacer or bearing cup (or something) that fits around the outer pinion bearing race between the race and transmission housing? :?:
If anyone has access to a parts diagram or assembly diagram for the 440ICD Pinion Shaft, I would greatly appreciate it if you could share it with me.
Thanks!
D.Light
1974 JD 350B Crawler Loader
joeturner1977
Post by joeturner1977 » Thu Nov 19, 2009 2:51 am
Hope this helps, Look at page 30-8 "ring gear and steering clutch assembly"
http://jdpc.deere.com/jdpc/pdfs/PC0609.pdf
-Joe
1958 420c w/mc60 blade
D.Light
Post by D.Light » Thu Nov 19, 2009 5:57 pm
Thanks for the parts manual! It had exactly the diagram I needed. :D
It is not looking good for my transmission.
We may decide to try to locate a replacement transmission.
Anyone have a transmission for a 440 ICD?? :?:
Thanks,
D.Light
Users browsing this forum: No registered users and 106 guests
