2010 vs 1010 diesel engine
if almost all the engine parts are exactly same on a 2010 as a 1010 diesel where does the extra power come from? Same block, crank, cam, sleave deck, etc etc. I don't see why putting a 2010 in a 1010 is going to create so much power that it would hurt my 1010 crawler.
thoughts on this would be helpful...
brian
brian
JD1010C My first John Deere
block is different sleeve is different bigger bore 145ci vs 155ci i dont think it would hurt to put the higher HP in the 1010 it has been done before you might have to watch just how hard you work her
I guess I got some bad info, my bad. I was told the block and sleave was eaxctly same ha thanks now I can see where little more power would be created.
I was doing some research because I need a 1010 sleave and found some posts where a guy was saying the 2010 is same and is actually cheaper to buy from john deere even thou it's the same ($900 vs $600). So you can see why I was confused. So I went out and loked at my newer model 1010 block and was comparing it to the 2010 block, looked the same. But I also have a older 1010 diesel block that doesn't look like the 2010 at all.
I was wondering where all the extra power came from
if anyone out there has a 1010 diesel sleave plate send me a PM, I guess I would also be interested in a complete 2010 diesel in working condition or short block.
![Smile :)](./images/smilies/icon_smile.gif)
Looking at parts manual for 1010 vs 2010 and the later 1010 diesel blocks are same part number as the 2010 diesel (T17513T), so I guess the sleave and pistons are only thing different. I wonder if same sleeve but just bored out a little more, or maybe the the plate is the same and the sleeves them self are just bigger.jtrichard wrote:block is different sleeve is different bigger bore 145ci vs 155ci i dont think it would hurt to put the higher HP in the 1010 it has been done before you might have to watch just how hard you work her
And your right the the 2010 gasser has same part number for sleeve as the 1010 diesel, I haven't found a after market place yet. Anyone know???
Brian
I believe Lavoy sells aftermarket engine kits for 2010 gas engines- however 2010 diesel engine parts (including deck sleeve) are supposedly Deere only.
There are a number of really good posts in the archives here about swapping 2010 and 1010 engines, as well as other John Deere machines like combnes and power plants. Do a search with my username, Lavoy or Jdemaris and you will find them.
2010 vs. 1010 diesel engine
Can a 1010 deck sleeve be bored out to accept a 2010 diesel piston? Would the sleeve deck need to be in the block to bore it? If this would work it would be a great way to get clean bore for the 2010 diesel.
Re: 2010 vs. 1010 diesel engine
THATS EXACTLY WHAT I WANT TO KNOW!!!mnwoody wrote:Can a 1010 deck sleeve be bored out to accept a 2010 diesel piston? Would the sleeve deck need to be in the block to bore it? If this would work it would be a great way to get clean bore for the 2010 diesel.
IF THIS IS POSSIBLE I COULD SAVE A BUNDLE BY SWITCHING TO A 2010... HA HA
does anyone know the piston size of a 2010? and 1010 is 3.625"
Brian
bingles wrote:THATS EXACTLY WHAT I WANT TO KNOW!!!mnwoody wrote:Can a 1010 deck sleeve be bored out to accept a 2010 diesel piston? Would the sleeve deck need to be in the block to bore it? If this would work it would be a great way to get clean bore for the 2010 diesel.APPEARS TO BE THE ONLY DIFFERENT IN 2010 VS 1010 DIESEL MOTORS.
Brian
I found it the 2010 diesel has a bore of 3 7/8" I will have to ask my machine shop if thats too much to take off and still cool good. then again I don't run this old girl too much.
No, it can not, there is no where near enough meat to do it. I am just too short on time right now to try and find all my manuals, but there are way more difference than you have listed. Only commonality between 1010 and 2010 that I know if is 1010 diesel and 2010 gas use the same deck sleeve. There are undoubtedly other things like glow plugs and such, but I highly doubt that blocks interchange at all. Not that something can not be cobbled together, but not factory.
I dont know just going by the part numbers out of the 2010 crawler vs 1010 Crawler, and the newer 1010 bare Block (T17513T) is the same part number as the 2010 bare block (T17513T), as with the crank, connecting rods, cam, bearings, valves, injectors, glow plugs and head. I see the pistons, sleeve deck are different as well with some other small things and probably injection pump but I don't know have not checked the pump serial numbers.
When comparing my 2010 engine to my 1010 the are identical on outside, but not my older block 1010 it looks completely different with respect to supports casted into the block and main bearing caps are thinner.
So ideally I could put 2010 pistons and sleeve in my newer 1010 block and have same factory stuff as the 2010 was shipped with. Again not sure about the injection pumps I will look and see. Also the 2010 parts manual I am looking at is for a 2010 Crawler and a 1010 Crawler.
I could be wrong this is just what I am seeing in part numbers... I have only taken 2 1010 diesel apart not taken a 2010 apart yet.
ya I hear ya, I started looking into this because every time I was getting part prices from my local john deere he kept saying that part is same as the 2010 and that the 2010 parts are more available used on ebay, then I go to ebay and almost everything says 1010 or 2010, so I downloaded both parts manuals and sure enough same dam thing except what I mentioned.
The 1010 is 40hp and the 2010 is 50hp I dont do hard work with my 1010, my thoughts are that I can run the motor a little lower RPM instead having to rev it up sometimes.
I am just trying to find cheapest way to get my old girl going... But seeing how I cant bore a 1010 plate kinda kills my options. I wonder how think a 2010 sleeve deck is? because it still has to fit into the same 1010 engine block and holes at the bottom. Does anyone have this stuff laying around so we could see?
As always Lavoy thanks for your tips!!!!
Brian
![Sad :(](./images/smilies/icon_sad.gif)
Brian
Users browsing this forum: No registered users and 104 guests
