Would that smoke be blue? I thought it would be white or blackLavoy wrote:Are you using the glow plugs? If not, they will almost never start. Check all 4 glow plugs, make sure they all work.
Pretty much all diesel 1010's smoke til they warm up, just a function of a pre-cup engine.
1010c hard atarting
- fruitcakesa
196? 1010 diesel crawler, Gearmatic 10 winch w/ arch/fairlead, 6 way power angle blade, ROPS w/rear screen
- fruitcakesa
So I checked the GP's and found 3 were NG.
I stole 3 from a spare engine I have that are good and now have 4 functional GP's and the dozer starts about 1000% better.
Still very smoky but this is a first step in fettling this machine.
- fruitcakesa
Hard Starting update
New glowplugs, longish glow cycle - 3 minutes +-, 2 batteries, liberal use of the primer pump and longish crank cycle= Start up at 20*. Use the tools JD provided it should work.
