1959 John Deere 440 IC Which Fluids?
I bought a 1959 John Deere 440 IC gas with a sixway blade a couple of months ago. It is in good shape but two cylinders for the blade leaked too bad to use. I took them off and had them redone. The arms were bent and it cost a arm and leg to have them redone.
I had several questions if somebody could help me out. I have the service manual. It says to use 10W hydraulic fluid. Also the motor oil needs to be topped off its about a pint low. It says 20W for summer and 10W for winter. Here are my questions.
1. Can i just put the cylinders on and top off the fluid slowly working the cylinders to move fluid in.
2. The auto parts store was clueless to what 10W hydraulic fluid is. Can you tell me what I need to buy.
3. For the 10W and 20W motor oil would 10W-40 or 20W-50 work or what should I use.
Obviuosly I'm no mechanic. Its a nice machine I don't want to make a stupid mistake with fluids. I appreciate any advice I could get.
Steve
Steve
tractor hydraulic fluid is what you want most parts stores have it and some walmarts do also and any good motor oil is ok you have to remember multi grade was not around back then
Thanks. Was I correct that all I have to do is top off the hydraulic fluid and slowly work the cylinder to let fluid back in?jtrichard wrote:tractor hydraulic fluid is what you want most parts stores have it and some walmarts do also and any good motor oil is ok you have to remember multi grade was not around back then
- Paul Buhler
Duke: What color is your existing hydraulic oil? If it's light coffee colored or milky, you may have water in it, and this would be a good time to drain and refill fresh. Lavoy has said that he uses hydraulic oil in his machines - I've forgotten the specs (they're posted on this site in another thread). I've been running 20w straight motor oil in Vermont year 'round without problems - I'll be changing over to hydraulic fluid next summer. Good luck with your machine. Paul
Thanks Paul.Paul Buhler wrote:Duke: What color is your existing hydraulic oil? If it's light coffee colored or milky, you may have water in it, and this would be a good time to drain and refill fresh. Lavoy has said that he uses hydraulic oil in his machines - I've forgotten the specs (they're posted on this site in another thread). I've been running 20w straight motor oil in Vermont year 'round without problems - I'll be changing over to hydraulic fluid next summer. Good luck with your machine. Paul
The fluid looked ok to me. I went by Tractor Supply today and they had no 10W hydraulic fluid. They told me I would have to go to a lubricant supply center and buy a 50 gallon drum of hydraulic fluid to get 10W. I was a little skeptical of that. I then went to O'Reilys and bought some AW-32 Hydraulic fluid that is suppose to be 10W. I think that should be OK.
Steve
I suspect you are right. I'm doing my best to adhere to the service manual on this old machine as I'm going to ask a lot from it. Is Hytrans what the John Deere Dealer sells?hydrogeo wrote:I run Hytran in my eqipmennt. I suspect these old machines are not particularly picky on the fluids, unlike the newer iron.
- fruitcakesa
Hytran is just a universal tractor hydraulic and trans oil. Most farm tractors use the same oil for both the trans and hydraulic systems from a common reservoir. I run the fancy synthetic stuff in my Kubota, but the old junk just gets standard hytran. I'm sure JD sells it. I get my fluids either at Tractor Supply (for the cheap stuff) or Napa typically. If you poke around on the web you will see references to how bad oil was back in the day compared to now. I suspect our cheap stuff now is far better than the best stuff back then.
I think HyTrans is the name of the fluids that Case sells- John Deere sells HyGard.duke1 wrote:I suspect you are right. I'm doing my best to adhere to the service manual on this old machine as I'm going to ask a lot from it. Is Hytrans what the John Deere Dealer sells?hydrogeo wrote:I run Hytran in my eqipmennt. I suspect these old machines are not particularly picky on the fluids, unlike the newer iron.
I would not say that HyGard is the same as a generic universal tractor fluid (UTF). UTFs are blended to meet the specs of many manufacturers including Deere. Hygard is specifically formulated for Deere machinery. Like Lavoys stated, it shouldn't matter for the application you are considering (loader hydraulics). However several on this board have mentioned that it can make a difference for powershift transmissions like a HLR.
Users browsing this forum: No registered users and 101 guests
