Frozen Hydraulic Cylinder on 62 Blade-Any Hope?
A friend gave me a really nice 62 blade with all of the hardware for my 40c. I was hoping to replace the Frankenstein looking deal I have now. My current blade is a perfect example of why coat hangers do not make for good filler rod.
I started getting ready for the swap and discovered that one of the hydraulic cylinders is frozen in about the middle of the stroke. It looks like somewhere along the line somebody took the hydraulic lines off and water got down the hydraulic ports. I tapped on the end with a 3lb sledge and it is locked tight. The other cylinder moves freely by hand. The paint matches the blade, so I assume these are the OEM cylinders.
Any chance this cylinder can be salvaged? If so what is the best way to go about it? Hook it up to the remotes on my tractor and put some hydro pressure on it (from a safe distance)? The throw it in the mud for a week trick? The two good cylinders on my existing blade are too short to use, and otherwise I'll have to wait until the money tree blossoms to get a couple new cylinders.
- Willyr
Nope its toast. you could salvage parts and pieces, yet the cost of rebuild is about the cost to replace. I suggest if it is a common cylinder that you visit your local Tractor Supply (if you have one). Or go online with either
NH Northern Tool and Equipment
http://www.northerntool.com/
Or Bailey Hydraulics if you have some weird size.
http://baileynet.com/index.php?id=0
Another possibility (very hit and miss) a salvage company of sorts.
http://www.surpluscenter.com/home.asp
former owner of a 1956 420c
I threw a pipe wrench on the end and got it to twist. I am going to soak ot overnight in ATF and see what tommorrow brings. I did not think of Surplus Center. I will see if they have anything close. Trator Supply doesnt stock anything close. Northern has one I will could make work for around $200, but I would want a matching pair..
- DukeofDeere
- Paul Buhler
I'd hook the hydro up and try to push the ram out of the cylinder. You may be able to put a seal kit in it and lightly hone the inside of the cylinder to get ride of rust and the thing may work great.
What is the condition of the chroming on the ram?
Ben
Well, did some diagnosis work. Here is what I found:
Rod looks great:
![Image](http://i481.photobucket.com/albums/rr178/hydrogeo/photobucket-8430-1335102966644.jpg)
Packing looks, well, OK
![Image](http://i481.photobucket.com/albums/rr178/hydrogeo/photobucket-19822-1335103009187.jpg)
Cylinder bore is down-right ugly
![Image](http://i481.photobucket.com/albums/rr178/hydrogeo/photobucket-1542-1335103050071.jpg)
I whipped up a long shaft for my cylinder hone and cleaned it up.
![Image](http://i481.photobucket.com/albums/rr178/hydrogeo/photobucket-2224-1335103077033.jpg)
I could hone it for a week and would not be close to getting all the pitting out. I am going to clean it up as best as I can and throw it back together. It should work for a bit, but I doubt it is going to hold up for long. Will start saving pennies for a new pair of cylinders. Oh, well, cost of a couple of cylinders is not bad considering how nice blade setup will be.
Rod looks great:
- Paul Buhler
A good day - learned something new.Thanks.
Found this link and other good info at it. Paul
http://baileynet.com/hydraulics/bailey_ ... and_tubes/
a basic video on measuring a cylinder:
http://baileynet.com/hydraulics/bailey_ ... enus_id=76
Your situation should be even easier now that you have every thing apart.
Users browsing this forum: No registered users and 82 guests
