420c Hydraulics
420c Hydraulics
My 420c with a #62 blade is painfully slow to raise the blade. It takes about 30 to 45 seconds to raise from the ground to full height. It also will leak down pretty fast when first started and gets better when it warms up. some times it works better than others ( as far as leak down ) . Is this the result of leaky check valves or could it be a weak pump. There is no leaking anywhere an I changed the fluid already with no change. Thanks
Fly Boy
