440 ICD Track Bushings
mark914
Post by mark914 » Sun Jun 03, 2012 4:42 pm
Anybody know if the track pins and bushings are available yet for the 440 ICD ? I knew mine were getting worn but now I see a couple of bushings wore completely through.
Post by Lavoy » Sun Jun 03, 2012 5:09 pm
They are current from Deere, little under $2000/set.
I am working on replacements now, but nothing in the short term.
mark914
Post by mark914 » Tue Jun 05, 2012 8:51 am
Thanks Lavoy. The bushings haven't been turned yet so maybe I can replace the ones that are worn through and have the others turned.
Post by Tigerhaze » Tue Jun 05, 2012 11:25 am
Hi Mark- you may find the cost of turning pins and bushings and replacing select ones or finding other used track may be the same as putting in new pins/bushings once you factor the labor and track press in, although not confident of that statement with Deere parts. Lavoy does track work so he would have a better idea on the cost differential.
jdemaris
Re: 440 ICD Track Bushings
Post by jdemaris » Wed Jun 06, 2012 6:58 am
mark914 wrote:Anybody know if the track pins and bushings are available yet for the 440 ICD ? I knew mine were getting worn but now I see a couple of bushings wore completely through.
If you've got some broke through, it's probably too late to turn them. I just went through the same thing. Deere used to recommend turning pins and bushings 180 degrees -but you never know for sure if it's worth it until the track is apart. I've had some that were well worn all the way around.
A guy near me has a small press and charges $400 per track to turn. Mine were so bad though, it wasn't worth it.
Local Deere dealer gets $2200 for pins and bushings for two 36 link tracks. Add that along with close to another $1000 labor, and then maybe worn chain links? That's what led me to search for good used tracks.
20 miles from me is a pair of 36 link tracks with two-bolt pads in REAL good shape. Pins and bushings and chain links near new condition. The place wants $1000 total for the pair of tracks. As I recall, they have dozer high grouse pads on them. I didn't buy because I wanted four-bolt chains and pads. Those tracks are in Sharon Springs, New York. I suspect the only reason they haven't sold is because they are already rolled up and off the crawler, and in the bushes. Hard to ID unless you've got specs and a tape measure (I did). I found almost new tracks with four bolt pads for $1500.
If my chains hadsn't been so worn, I would of bought new bushings from Deere but made my own pins. Deere gets $720 for the 36 bushings and near $1500 just for the pins. You can buy hardened 4140 1" pin stock for a little over $500 and make your own pins. 1050 steel would cost around $275 but it should be hardened will adds to the cost. Each pin is 1" OD by 5 1/2" long. 72 pins comes to 34 1/2 feet of one inch stock. Deere pins are made from 1050 steel and hardened. I use 4140 prehardened when I make pins.
Post by Lavoy » Wed Jun 06, 2012 7:39 am
If one is worn, they are all worn, just a couple of them have perforated. You have to replace all of them, you can't just replace a few.
If you make your own pins, keep in mind that 4140 pre-hardened is about half the Rockwell of an original pin, give or take.
jdemaris
Post by jdemaris » Wed Jun 06, 2012 2:34 pm
Lavoy wrote:If one is worn, they are all worn, just a couple of them have perforated. You have to replace all of them, you can't just replace a few.
There are many ways to do it. Deere "Duratrax" pins and bushings are made for Deere by Berco, last I checked. They use 1050 steel and induction harden to HRC 60 with a hardness depth around 3/32".
4140 prehardened rod comes in hardness ratings from HRC30 to HRC54 from the sources I've used.
You can also use A2 air-hardenable rod and harden yourself. It will harden to HRC60-62, just like the Berco/Deere/Duratrax. Problem is it is not often cheap. It's been $2 to $2.50 per inch lately. That come to around $14 per pin which makes the price of the Deere/Berco pins not so bad.
W2 water hardenable rod is cheaper at $1 per inch and hardens to HRC54. Also not bad for a part time user machine. Costs around $6-$7 per pin.
I made my own pins in my Allis Chalmers HD6 crawler 10 years ago. It's a part time user and can't say how many hours it has since I did it. I used 4140 that was rated a hardness of HRC50. I turned the bushings but made new pins since the old ones were worn all the way around. Since I did it, I haven't even had to readjust the tracks. Now - if it was an all day, every day user - I'd made more of an effort to get harder pin stock.
To "each his own." If I made pins from any of the materials I've mentioned, they'd out-last me, but I don't use my crawlers all day, every day. If somebody plans to use a 50 year old crawler that much, there will be many other issues to consider besides Rockwell "C" hardness.
