top roller
top roller
the right hand side top roller on my 420 is worn bad but only on the outside. I'm pretty confused because nothing else is worn more than it should be. but anyway, pretty sure i remembered that i read on here the top rollers are cast?? will a top roller off of any other model work, like maybe a 350?
Home of the free because of the BRAVE!!!
1957 420 5 roller 5 speed
You might need to check your alignment. I know on my 440 the left rear is out a bit far, so it pushes the top idler out some, thus causing the track to wear on the outside.
I was able to spot this because I noticed where the sprocket sits up in the back idler the gap on each side wasn't even.
The book details how to align all of the undercarriage components.
Ben
420 through 2010 are the same roller (not the bracket) the only new rollers that you can get (that i know of and hard to find) are 350 which you can use BUT you need to push the inside bushing in about 3/8 inch and machine the end of the roller to except the new 2010 style seal (standard lip seal) or see if Lavoy has any used if he don't try don Peila tractor 541 772 1801 or 541 842 4331 if he don't there 3 on eBay but they are around $250 with bracket.... one other thing you can do is if it is not worn down into the bolt holes you can weld it up
They are actully both, they are cast steel. I do have a new upper idler on hand if you want one.
I would check with Lavoy first. He can usually meet or beat Deere price on most anything. Besides he owns this site and sells parts which makes it possible for us to come here for help, information and parts.
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
Shaft is pressed in, comes out easily in a press.
I have new shafts on hand.
Users browsing this forum: No registered users and 80 guests
