What kind of tractor is that?
Martial
Post by Martial » Wed Aug 28, 2013 1:41 pm
Good day all
I am new to this site and would like to know the model of this tractor
Will then buy books and start complete restauration
By the way, are the parts difficult to find?
Tractor is starting great (gas two cylinder)
No template on it
https://tractorjd.shutterfly.com/
Thanks a lot
Martial
[/url]
MARTIAL
Post by Lavoy » Wed Aug 28, 2013 2:38 pm
It is a 420, above about 109,000 serial number with a factory Deere #90 loader.
Parts depends on what you are looking for, but I stock a lot of parts for them.
Martial
Post by Martial » Wed Aug 28, 2013 7:07 pm
Lavoy wrote:It is a 420, above about 109,000 serial number with a factory Deere #90 loader.
Thanks Lavoy,
Just do not know yet which parts I may need, but would there be some parts that should start checking so that if they are worned out, it is not worthed the restauration as it will be too expensive?
Any idea where I could buy the spares part book, maintenance and owner manual?
Regards
MARTIAL
Gil
Post by Gil » Wed Aug 28, 2013 9:06 pm
The Parts Manual is available free on-line from John Deere at:
Search for "420".
Lavoy or eBay are sources for the Service Manual. The Operators Manual is less important as the same material is covered in the Service Manual.
If your engine is running well, the most important components to look at are the undercarriage - the tracks, rollers, sprockets, etc. You will need to do some research on this site or have someone with some crawler experience help you evaluate the condition of your undercarriage components. Gil
Post by Lavoy » Wed Aug 28, 2013 11:25 pm
As a general rule, none of them are ever worth the restoration in terms of dollar value. If the value of the machine once it is done vs the dollars spent is of any concern to you, don't start, you will only be disappointed.
If you want to have own the machine for years, play with it, work with it, and someone else can worry about the value at the estate sale, they are probably one of the funnest things you will ever do.
Users browsing this forum: No registered users and 21 guests
