1010 question
- lcfrace
- Contact:
1010 question
I installed a steering clucth in the one side. I jacked it all up so I could test it before installed the track back on. When I put it in gear only the side turn that had the track off. Is this normal? If not what other problem may I have. Thanks Larry
1010 JD Crawler, 310 Case dozer, 977 Case track loader, RayGo roller
- DukeofDeere
Did you make the proper adjustments with the throw out bearing, and brake band? I just installed a set of clutches on a 1010 and did the same thing. Wouldn't move because brake band was too tight. Just a thought.
Andrew
Andrew
440 ICD 64 blade & 8a gear attic winch
440 ICD 831 loader with scarifier and weights
420 62 blade 3pt
Looking for 24 scarifier and 440 log arch
420 62 blade 3pt
