John Deere 2010
Pilgrimwoodcraft96
John Deere 2010
So our family farm has had a 2010 sitting in the barn for ages. I asked about it and it is said to not be able to steer left, it hasnt run in years but all gas was drained. I pulled the seat, and un bolted the small covers. The Right side has oil in it and the left is dry, and when pulling the right steer arm there's resistance, but the left one is so loose, theres no resistance to the pull. Any ideas, i had heard of the clutches freezing open, is that a possible problem, and is the oil on the right bad?
Ben
Ben
- DukeofDeere
Pilgrimwoodcraft96
the right is new seals and brake band and most likley clutches if either or both have oil on them they are junk... the left is so swolen with rust that the fingers are way down away from the throught out bearing that is why you dont have any resistance on the lever..... needs new clutches and brake band also
Pilgrimwoodcraft96
- DukeofDeere
