![350 crawler 350 crawler](./images/ranks/wrench/spanner_rank_5.gif)
Post
by jtrichard » Wed Nov 26, 2014 12:33 pm
YES IF you have good flow then thats what you want ( unless there are no filters in there?)
![Surprised :o](./images/smilies/icon_surprised.gif)
treefort
![40C crawler 40C crawler](./images/ranks/wrench/spanner_rank_0.gif)
Post
by treefort » Wed Nov 26, 2014 12:34 pm
He he oh jeez. Hopefully that is not the case!
Post
by jtrichard » Wed Nov 26, 2014 12:40 pm
when you get new filters make sure to get the gaskets and remove the old ones (best to use an ice pick) up in the base they will be like concrete most likely....the first time i did mine i did not think there was any in it they were as hard as the casting lol
![Shocked :shock:](./images/smilies/icon_eek.gif)
jtrichard on Wed Nov 26, 2014 12:49 pm, edited 1 time in total.
treefort
Post
by treefort » Wed Nov 26, 2014 12:48 pm
Ok, will do.
Quick question, why do I need the 2 wire cable you posted for the alternator? I see that the description states the brown wire with the diode is what you need when replacing a generator like I have..when the machine keeps running after the key is shut off. But I would have thought I would only have needed the power and ground wires to the battery? When it spins it produces..but obviously I'm missing something here.
Thanks!
Post
by Stan Disbrow » Wed Nov 26, 2014 12:52 pm
Until the filter element deteriorates and splits and lets all the junk pass to the injector pump. Been there, done that, and do not -ever- want to go there again.....
Filters are dirt cheap (pun intended)!!
Post
by jtrichard » Wed Nov 26, 2014 12:59 pm
sense you have a diesel you may not need the diode (STAN WHERE ARE YOU) but you will need 2 wires UNLESS you get a one wire alternator ..... one of the wires is to the battery cable on starter other is the exciter signal from key switch and can go through? the dash light (AGAIN STAN WHERE ARE YOU LOL) he is the electronics wizard around here
![Very Happy :D](./images/smilies/icon_biggrin.gif)
treefort
Post
by treefort » Wed Nov 26, 2014 1:56 pm
Ok, I'll make a point of making sure to change the filters and get gaskets in the spring!
I just did a little reading. Not sure if I need the diode either because I don't have to worry about it keeping the engine running as I don't have a solenoid for the injection pump, ignition, etc. Anyways, I can deal with the wiring when I get the alternator!
![Wink :wink:](./images/smilies/icon_wink.gif)
Post
by jtrichard » Wed Nov 26, 2014 3:24 pm
if you use the dash "GEN" light then you dont use a diode even on a gas rig
treefort
Post
by treefort » Wed Nov 26, 2014 3:45 pm
Ok, sounds really good. I am excited to get the alternator! And fix the glowplugs. What do you think the best way of me fixing that broken connector would be Patrick? Get a new plug? Can I keep the wire? I can ask the local dealer here for a glowplug unless you think ebay would be a better bet?
![Smile :)](./images/smilies/icon_smile.gif)
Post
by jtrichard » Wed Nov 26, 2014 4:24 pm
PATRIC???
![Laughing :lol:](./images/smilies/icon_lol.gif)
I think Lavoy has good glow plugs JD gets like $100 .00 each these days ... i have heard horror stories about EBAY ones i need to see pic to see if yours can be fixed or???
treefort
Post
by treefort » Wed Nov 26, 2014 4:28 pm
Oh man I'm sorry Richard! I'll get a pic for you here in about half an hour
treefort
Post
by treefort » Wed Nov 26, 2014 5:04 pm
OK so taking a better look I have two broken off at the plugs
Here are a couple pics of the broken ones and one of a good one. I'll need to put new wire on them too as its looking pretty rough.
http://s1161.photobucket.com/user/tdanc ... oads/story
treefort
Post
by treefort » Wed Nov 26, 2014 6:12 pm
Added a fourth picture of the only lever by my feet. It was currently up in this position. Is this the HLR disconnect? Right noe its up all the way hitting the Steering levers guard. I can only swing it lower to the back of the crawler.
Post
by jtrichard » Wed Nov 26, 2014 8:16 pm
get some pics of the whole tractor thats not a 2010 im guessing 1010
![Confused :?](./images/smilies/icon_confused.gif)
treefort
Post
by treefort » Wed Nov 26, 2014 8:21 pm
Hi Richard, its a 2010 in a 1010 body. Forgot to mention that. Good eye!
Users browsing this forum: No registered users and 90 guests
