2010 crawler transmissoin
pippess
Post by pippess » Fri Jun 19, 2015 5:34 am
not getting any fluid out of transmission lines dont know why anyone please help :? :?
Post by Lavoy » Fri Jun 19, 2015 8:21 am
Possible plugged filter or inlet screen?
Post by jtrichard » Fri Jun 19, 2015 11:31 am
IF you are talking about the cooler lines up front? having NO fluid then pull the right floor plate and look to see if the lines have been plugged off OR bypassed (near the filter) because one of the STEEL lines to the cooler rusted through ...I have had one of those lines rust through (from the OUTSIDE) and replaced it with copper GOOD luck and WELCOME to the NUT HOUSE :D :D :D
pippess
Post by pippess » Fri Jun 19, 2015 7:10 pm
Lavoy wrote:Possible plugged filter or inlet screen?
thank you for reply i have check all filters changed fluid twice .would you know what drives the fluid and where would the pump be .
pippess
Post by pippess » Fri Jun 19, 2015 7:19 pm
jtrichard wrote:IF you are talking about the cooler lines up front? having NO fluid then pull the right floor plate and look to see if the lines have been plugged off OR bypassed (near the filter) because one of the STEEL lines to the cooler rusted through ...I have had one of those lines rust through (from the OUTSIDE) and replaced it with copper GOOD luck and WELCOME to the NUT HOUSE :D :D :D
hey jt thanks seems like i mite be spending sum time hear just got the old girl running thought it would just move and work but it has failed i was told that it was running and moving then the motor went k poots so i got this for dang near nothing and got amotor and now wont move like to get a good repair manual not sure wear to look . well thats the story thank for the welcome from you both.
Post by jtrichard » Fri Jun 19, 2015 11:18 pm
here is one http://www.ebay.com/itm/JOHN-DEERE-2000 ... 3a86e0dbf8 where do you live (you did not fill that in on your profile ) here is parts also you NEED both http://www.ebay.com/itm/JOHN-DEERE-2010 ... 339f7c9fc4 what do you have loader or dozer? there are parts books on both loader and dozer separately also .... pump for HLR is on the front of trans in the bell housing you need to get the books so you can do pressure checks by the book .... what is the ser# ? any pics of the machine? NEED as much 411 as we can get :D :D :D
Post by Stan Disbrow » Sat Jun 20, 2015 5:25 am
I have been working on the List-O-Manuals, so what you need is in the FAQ section of the site:
http://www.jdcrawlers.com/messageboard/ ... 5332#55332
The list is in a long first post, and it is organized by timeline, so just scroll down until you get to the 2010. :)
You can get manuals either from Deere directly or off of eBay.
pippess
up and moving
Post by pippess » Sun Jul 26, 2015 5:40 pm
well gentleman up and running found out after 12 years of sitting things did not move like they used too even us .so the clutch disconnect lever was not working right so after i got it working like a cats meow .started it up and sure enough she is alive .working know on gauges .thanks for all your input it was real helpful .is there anyplace to get the gauges still
Post by jtrichard » Sun Jul 26, 2015 10:23 pm
that makes sense as to no oil pressure ....if dirt builds up under the trans disconnect it will NOT apply after you release the lever ... you never said that NOTHING was working and none of us here though to ask :oops: :oops: at least you got her up and running :D :D :D
shinnery
Post by shinnery » Mon Jul 27, 2015 7:55 pm
Thanks for letting us know what you found. It gives some closure to the efforts. Many good hours of digging ahead.
Users browsing this forum: No registered users and 20 guests
