420c steering clutch
jag1964
Post by jag1964 » Mon Jan 11, 2016 10:21 pm
I bought a 420c several years ago, starts fine, good power, however the left steering clutch does not seem too disengage, I adjusted the throw-out bearing as far out as possible, still no release. I removed the final, the clutch pressure plate and discs appear new. the steels are clean, however appear to have been corroded and cleaned at some point. I found some pieces in the bottom of the case which appear to be from the pressure plate.
I wonder if the pressure plate was not adjusted correctly on assembly?
Clutch discs
http://i1075.photobucket.com/albums/w42 ... w5y8li.jpg
Steels
http://i1075.photobucket.com/albums/w42 ... qaj717.jpg
Spare parts
http://i1075.photobucket.com/albums/w42 ... g1vkci.jpg
Pressure plate
http://i1075.photobucket.com/albums/w42 ... 45ubep.jpg
Also several of he bolts holding the tracks on, were rusted 1/3 the way thru, Does Lavoy sell spares?
http://i1075.photobucket.com/albums/w42 ... sdsed6.jpg
Thanks in advance for the advice
420c
Post by Lavoy » Tue Jan 12, 2016 8:47 am
Something is odd with the wear pattern on the one fiber disc, it appears to be only on the very outside, this is not right.
The clips are from the pressure plate levers, someone left them on when installing the pressure plate, they should not be there. If the clips were on when the clutch was assembled, chances are the pressure plate was never adjusted. This may not be the problem, but worth checking.
I think I have some of the bolts on hand, would have to check.
Post by jtrichard » Tue Jan 12, 2016 9:34 am
Lavoy what you are seeing is actually a steel behind the fiber I had to look a few times at that pic my self :? :?
Post by Lavoy » Tue Jan 12, 2016 4:17 pm
Ok, that makes more sense.
jag1964
Post by jag1964 » Thu Jan 14, 2016 6:13 pm
Yes exactly, the clutch discs look brand new, with the part number still on them, the picture does show the disc on top of a steel in the background.
The steels all measure 0.095 +/- .001-.002, however they all have a funny texture to them rather then being smooth.
I am thinking I need to replace the steels, get the gauge for adjusting the pressure plate and reassemble it.
Does that make sense?
420c
Post by jtrichard » Thu Jan 14, 2016 6:44 pm
can you post a pic of the steels?
jag1964
Post by jag1964 » Fri Jan 15, 2016 9:55 pm
All the steels look about the same, on both sides, like they had some corrosion that was cleaned off leaving some pitting. It seems to be worse around the perimeter.
420c
Post by jtrichard » Fri Jan 15, 2016 10:30 pm
Yes they have been cleaned ....... 50/50 replace or not
jag1964
Post by jag1964 » Sun Jan 17, 2016 11:41 am
I think that given the work involved I won't risk reusing the steels, buy new and adjust the pressure plate, Hope for the best.
420c
Users browsing this forum: No registered users and 363 guests
