repair or not to repair ?
Front Idler torn apart roller shaft mics 0.020 diff than factory specs, roller bushings mic.1204 diff, replace ? do it now cuz it's tore apart, let it go cuz it's a tractor by gosh?As always any help will be appreciated to the max
PS; JD420-C
PS; JD420-C
That is over an 1/8" of total wear if I am reading your figures correctly. So to me, that is a ton of wobble, and do you want to ever tear it apart again, or just once?
That much wobble means a really good chance of dropping a track off. And, that will *never* happen in a good place to get it back on!
I would agree with Stan's assessment, given that I NEVER drop a track on level or dry ground.
measures
Once again I may have misled, apologies, Here's the comp's
!: Factory specs on Idler & roller shaft (they're the same)
1.981- 1.982-----------I read 1.9625
2. Idler & Roller Bushings---factory: 1.983-1.987------------------------------------ Read------2.037- 2.0125 opposite sides diff of .1204 from factory. Waddya think?, Steve
I still think you have a decimal point off somewhere, or I am missing something. .125 is an eighth of an inch, and you say you are off .1204.
dec point
I carried the .1204 to far is all, it's still .120 or close the bushings vary a little side to side, probabably should replace, still almost an 1/8" thats too much, so let me know what you can supply.
Yes, .120 is way too far. Normally with new bushings and shaft, it is even a little difficult to push the shaft into the new bushings.
I have all of the parts available except maybe the thrust plates, and lots of times you can reuse them if need be.
Hi,Tigerhaze wrote:I would agree with Stan's assessment, given that I NEVER drop a track on level or dry ground.
Or anywhere near the shop. Always happens at the point furthest from the shop!
droppin a track
Why can't you drop a track at the barn door or the lawn in front of the house, oh right, it's Gods way of sayin, you're havin to much fun!!
Users browsing this forum: No registered users and 78 guests
