Steering clutches for a 1949 JD MC crawler
Help. I am in the process of repairing my steering clutches and brake rings on my MC crawler. I have replaced the metal and fiber and brake bands. It seemed pretty simple until I reinstalled both sides back on the crawler. Now when i tighten both sides up 2nd gear grinds and will not work and when I torque both sides the left shaft stops turning when in gear like it is bound. When i Losen the left side bolting it will turn. I am at my wits end as I have had these back off and on now a number of times and cant seem to find a problem
There is nothing you can do as far as steering clutches that would cause second gear to grind unless I am really missing something.
Any of the gears grinding would have to indicate that the main engine clutch or pilot bushing is dragging causing the input shaft of the transmission to keep turning when the main clutch pedal is depressed.
You do have to wait 2-3 seconds on any of these old machines before you try to engage a gear, though. You have to let the input shaft slow or they will grind a bit. Maybe you are just being too quick to move the gearshift?
Upon rereading....maybe you have a cracked trans case....only messes up when you have the weight of the final drives attached?
Folks thanks for the input. I could have been a little clearer with my original post. I will try to answer your questions. My Crawler was running with no drive train issues except the brake issue. I originally was just going to repair the brake band. It would go into and operate in any gear. I made the repairs and while I was there I replaced the clutch pads. I reassembled everything and now the clutch works but if it is in second gear and you let out on the clutch it sounds like you are trying to put it in gear with the clutch out. Again if the bolts are all loose the drive shafts turn and all works well but as i tighten them up the left shaft stops turning. When the bolts are lose i can operate the clutch and brake and everything works as it should ?
Which bolts do you mean? If you are talking final drive case, you have something together wrong, take it back apart see what it is, I would not run it til you know for sure.
If it only does it in second follow Lavoy's advice first, and then take off the transmission cover, hook a bent welding rod around each shaft and try to raise it. Sounds like a spun out bearing along with some serious resistance in the left final drive.
Hmmmm. That makes sense. Two troubles. The new brake is binding and loading the transmission, and it has a bad bearing - which didn't show up earlier because it wasn't under a heavy load.
I have disassembled it again and verified that all components are stacked in correctly the only thing left could be the pressure plate adjustment. I believe that the spring clips on the pressure plate are rubbing. Again I get a grind from no gear enguagement when I put it in second gear and let out on the clutch. Is it possible that I have pushed everything to one side when I installed the other side
- Paul Buhler
I don't know if an MC is set up the same as a 420, and I don't know why this only happens in second, but when you reinstalled the clutch pack, did you use new bolts to hold in the clutch plate? If so, they may be rubbing on the final drive housing. I put my 420's pressure plate mounting bolts in with the heads facing the final housing and the nut ends inboard so that this wouldn't happen. Best wishes.
http://s460.photobucket.com/user/pbuhle ... l.jpg.html
I've gone by and taken a look at his machine. It seems the outer edge of the throw out bearing is maybe hitting the the pressure plate fingers. Right now if the left side cover bolts are loose, 1/4" gap between cover and box, the trans will go into gear and the axles will drive. If those bolts are pulled up tight the left side will not pull at all as if the throw out bearing is pushing against the pressure plate fingers disengaging it. It also has to be getting really deep for the edge of the bearing to be getting shined up the way it is. We are missing something on this side and trying to get a little direction on it.
It think your assessment on 2nd gear is likely right. It grinds in 2nd gear and does not seem to matter about what is going on with the drive. We have not yet had the cover off to look inside the trans, trying to get the final drive worked out first. As to this bearing, if 2nd gear is just not used will that be ok? are there other gears on this same shaft?
DC
DC
Did you adjust the steering clutch after installing the final? If the throwout bearing is hitting the fingers, it needs to be adjusted properly.
Users browsing this forum: Google Adsense [Bot] and 322 guests
