re.jd40 vs 40s whld
re.jd40 vs 40s whld
see if this works...post any additional info here
re.jd40 vs 40s whld
so my other post shows to be 28 reply yet only 11 showing where dey go???
Into what we used to call the Bit Bucket.
Back in the Olden Days when IBM roamed the Earth, computers were programmed with Hollerith Cards. AKA Punch Cards. They were 80 columns wide and they had places punched out where the zeros were.
The machine which did the punching had a keyboard for the human and was known as a Keypunch. It had a wastepaper can underneath to catch the little pieces of punched out card.
Each piece was called a Bit and the can they fell into was called the Bit Bucket!
I have a Bit Bucket left over from my IBM days. I use it as my trash can in my electronics shop.
Anyway, we still refer to lost data as having gone into the Bit Bucket.
Now, if this post makes it.....I entered the first paragraph and then used Edit for the rest.
re.jd40 vs 40s whld
Stan,
ok..try to do same on 1st post to see if get pg. 2 and see if pickup rest. where edit button?
so i found edit button...tis there when you open discussion and can get back to the post....
now will see if it works
thanks
dtoots1
thanks
dtoots1
Yeah.
You submit the reply, then wait for the board to return you to the discussion, then hit the Edit button and write the rest.
Like this post. I hit Reply then entered Hi and Yeah. Then I submitted it and it went and I waited for the board to redirect me back to the thread.
Then, I hit Edit and wrote the rest of the post and submitted the edit....
Second Edit: And I see where that worked as I expected.
Yeah.
Users browsing this forum: No registered users and 292 guests
