radiator cap bfor jd40s
dtoots1
Post by dtoots1 » Thu Oct 17, 2019 9:50 am
Lost my radiator cap for my jd40s wheeled tractor 1954.
Do you have available replacement cap or can i get usable at napa? not having issues with it off so appears doesn't require pressurized???
Re: radiator cap bfor jd40s
Post by Lavoy » Thu Oct 17, 2019 10:14 am
Uncommon cap as far as parts store, but I have them on hand,
Post by Stan Disbrow » Fri Oct 18, 2019 4:54 am
No, they aren't pressurized. Thermosiphon system, so no water pump. Pressurizing will restrict the natural flow of water and cause overheating. You could use a pressure cap and drill a hole thru the center. But, then it won't have the copper wool packing which keeps the water from spitting out thru the vent hole. Best to get a proper old type cap.
dtoots1
Re: radiator cap for jd40s
Post by dtoots1 » Sat Oct 19, 2019 6:49 am
If you will, go ahead and send me one....you still have my card number on file..thanks
dtoots1
Post by Lavoy » Mon Oct 28, 2019 8:21 am
Dennis,
Give me a call with your info again if you will.
Users browsing this forum: No registered users and 159 guests
