hey everyone, looking for some guidance
KPaXz
Post by KPaXz » Wed Oct 08, 2025 11:24 am
i hear there is a message board here that teaches one how to use the clutch plate adjuster tool. the tool is metal, flat and has a few cutout guides on it. there's suppose to be a way to use it for adjusting john deere 420c clutch pressure plates. any direction to where this guide might be on the message board? ive looked and cannot seem to find it, thanks
Re: hey everyone, looking for some guidance
Post by Jim B » Wed Oct 08, 2025 2:25 pm
I think there several copies of the service bulletin # 286 about the tool floating around in different threads here. Here is a photo of it.
KPaXz
Post by KPaXz » Thu Oct 09, 2025 8:51 am
thank you very much. picture sent me in the right direction
KPaXz
Post by KPaXz » Sun Oct 12, 2025 7:37 pm
this video gives a shoutout to lavoy and also explains how to use the tool pretty well. https://youtu.be/9poGqXPOJzg?si=sO8rWlKSWwY1YEdZ&t=573
KPaXz
Post by KPaXz » Tue Oct 21, 2025 12:46 pm
so an update on the clutch pressure plate and tension fingers. the nut and bolt that adjusts the clutch plate fingers are so seized up i cannot loosen them. I've sprayed them down several times with PB blaster, no luck. starting to look like ill have to find replacement nuts and bolts and drill the old ones out or buy a used/new clutch pressure plate. any suggestions are welcomed. thanks in return
Post by Jim B » Tue Oct 21, 2025 3:41 pm
About the only pressure plates I have rebuilt for years are the two stage ones on bigger tractors that cost a lot more. I know costs add up but a 420C pressure plate is not expensive compared to the ones I am used to, nor is a complete clutch kit. Springs can be weak, pins worn, etc. which can reduce service life.
If you buy a pressure plate, buy a new one. My personal choice, I would have put all new clutch parts in for the cost of a 420 clutch vs the risk of doing the job over. What new clutch parts have you installed? Lavoy sells quality parts at fair prices, if you need.
Post by Lavoy » Wed Oct 22, 2025 9:54 am
This is one of the main reasons I never reuse pressure plates, total PITA.
New ones on the shelf.
KPaXz
Post by KPaXz » Mon Oct 27, 2025 6:34 pm
thank you guys. the only parts I've installed so far is the clutch plates. did some electric wire brush cleaning on some mild rust within the clutch plate housing. my left side steering handle is completely seized up. going to have to tear that apart ASAP. was a miracle i got that old girl out in the middle of winter when i did.
Post by Jim B » Mon Oct 27, 2025 8:09 pm
To be clear are you working on the engine clutch or a steering clutch? They all get adjusted with the tool, but some related answers to question might be different depending on which clutch.
KPaXz
Post by KPaXz » Mon Nov 03, 2025 2:42 pm
working on the steering clutch final drives.
