Clueless 420 Crawler Owner
Hello I just joined this group because im looking for more information... I have a old crawler and thats really all I know... I think its a 57 MC 420 dozer.. Definitely needs restored but was running when parked over 20yrs ago!!! Please help, is it worth putting for sale..or wat would u do?? My grandpa is no longer here for all my question
.. LOCATiON WESTERN,NC LOCATION
Re: Clueless 420 Crawler Owner
57 would make it a 420. There are quite a few differences between a 420 and an MC. Such as a 420 has a water pump and an MC does not. An MC would be a 3-roller undercarriage only as well. Most 420s have a 5-roller with the 4-roller being an option.
You would have to get it going if you wanted more than scrap metal value for it. And, that might wind up being a lot of work.
Where in Western NC? I am in the Raleigh area, so Western NC might mean a reasonable drive or maybe not.
Im trying to figure out how to upload pics... I was told a 5 roller.. the guys on FB says its not a MC..and kinda got offended that I said it was lol it has a mc sticker on it but I know that holds know weight..
Small town of fallston,nc... more cows than ppl
5 roller has to be at least a 40, and as mentioned, if it has a water pump, then 420, years we can pin down later.
- Canuck 420c
- Contact:
Welcome to the forum
420 crawler serial numbers
1956 (Phase 1 / All Green): 80001 to 948181957
1957 (Phase 2 / Green & Yellow): 100001 to 1197641958
1958 (Phase 3 / Slant Steer): 125001 to 136868
Nothing Crawls Like a Deere
Fallston, NC is a 3 1/2 hour drive for me. There might be someone closer.
Dear Clueless,
First of all.....are you in anyway familiar with working on automobiles? Handy with tools, common sense, can change spark plugs/ oils etc...in other words kinda basic mechanical knowledge??
Read all the posts pertaining to jd420 machines...most have quite a bit of info relating to getting these things up and running so you can get and idea of what all needs done to do so...
This group is always very helpful when you get down to the nitty gritty....Lavoy the owner of site...is well versed in these machines as he literally rebuilds these things...
If going to try to start this machine....1st...check oil level....was this in a closed building or under cover or at least had exhaust covered it likely should not have water in the oil...does it appear to be clean....next is fuel....tank probably either rusted inside...empty or full of gunk...fuel is gravity fed so possible to use..for test purposes a jury rig to get fuel to run to the carb....next is spark....these normally use a 6 volt battery positive ground...check distributor to be sure points clean and contacts clean...radiator not an issue as long as only starting for a couple minutes to see if will run...
once determine running....you can then make a choice as to what to do with machine...
my post jd420 pics....goes from start to finish what i had to do..
Dtoots1
Dtoots1
Users browsing this forum: No registered users and 68 guests
