440ICD 602 Project.
jimmydiesel
440ICD 602 Project.
Post by jimmydiesel » Thu Jul 09, 2026 11:42 pm
I got this 440 in June of 2022. It was tired but with some adjustments and a handful of minor repairs it has been a work horse.
The clutch had started slipping so out came the engine.
When the engine separated from the bell housing about a quart of engine oil poured out. The drain hole was plugged up with a piece of a cut off bolt and oil sludge.
The engine wasn’t using much oil (especially for a Detroit) so it appears the rear seal has a slow leak that couldn’t drain out the bottom
and built up inside the housing. Check those drain holes.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
sweeperman
Re: 440ICD 602 Project.
Post by sweeperman » Thu Jul 16, 2026 3:07 pm
nice engine hoist
jimmydiesel
Post by jimmydiesel » Fri Jul 17, 2026 4:39 pm
nice engine hoist
Thanks.
It is the most used pice of equipment I have.
440 ICD 831 Loader
440IC 831 Loader
jimmydiesel
Post by jimmydiesel » Sat Jul 18, 2026 10:50 pm
New front and rear crankshaft seals, new camshaft and balance shaft seals.
New clutch,release and pilot bearings.
New friction disk’s for the throttle control.
New oil, belts and antifreeze. Engine is reinstalled and running. Lowered the idle speed and raised the governed speed.
440 ICD 831 Loader
440IC 831 Loader
Users browsing this forum: No registered users and 65 guests
