Cylinder Sizes of Model 64 Blade
jackhdn
Post by jackhdn » Mon Dec 07, 2015 9:43 am
Hi Guys,
I've decided to build a power 6-way for my 440 this winter. Can someone tell me the approximate sizes of the hydraulic cylinders on the factory blade? Bore, stroke, and rod diameter.
Thanks very much.
Jack Hayden
Buckland MA
shinnery
Post by shinnery » Mon Dec 07, 2015 11:53 pm
I have one laying out back with one broken rod on one angle cylinder. I will try to get around it with a tape measure. The rod is broken where it is cut down to attach to the blade.
shinnery
Post by shinnery » Thu Dec 10, 2015 8:47 pm
The blade I have has a total of 5 hyd. cylinders. The two main ones (I will call raise) are 2 1/2" x 18" stroke with a 1 1/4" rod and have 4 outside assembly bolts. The two angle cyls. are 2 1/2" x 18" w/1 1/4" rod (the rods are turned down to 7/8" and threaded to go into the end fitting {one on mine is broken there}). The tilt cyl. is 2 1/2" x 8" w/1 1/4" rod. HTH Only the raise cylinders have the outside bolts.
jackhdn
Post by jackhdn » Fri Dec 11, 2015 6:49 am
Thanks Bryce. The measurements are much appreciated.
Jack
Users browsing this forum: No registered users and 237 guests
