Track pads
mapaduke@yahoo.com
Track pads
Post by mapaduke@yahoo.com » Mon Dec 21, 2015 6:11 pm
I have several stamped track pads that I want to use for my MC but the mounting holes are ovaled out from running them lose, any thoughts on how to fix these?
nothing crawles like a deere
Post by Lavoy » Mon Dec 21, 2015 6:38 pm
Depends on carriage or hex head bolt style pad. Easiest way is probably to put a washer under the bolt and torque the hell out of it. If you want to take the time, you can weld the washers to the pads.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Mon Dec 21, 2015 6:48 pm
Thanks Lavoy, that's pretty much what I was thinking.
Do you have a stamped pad, I'm missing one they have the hole in the center?
Thanks Ron
gregjo1948
Post by gregjo1948 » Tue Dec 22, 2015 5:36 am
Can you over bore and use larger bolts?
Post by Lavoy » Tue Dec 22, 2015 8:32 am
Stamped snow pads are difficult to non-existent, sorry.
No, you can't overbore, not enough meat in the link, plus that would be a lot of work.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Wed Dec 23, 2015 12:31 pm
http://rs877.pbsrc.com/albums/ab331/MAP ... 0&fit=clip
Maybe I shouldn't use them if there that hard to find?
Post by Stan Disbrow » Wed Dec 23, 2015 2:01 pm
I have never seen those before. Must be uber-rare.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Wed Dec 23, 2015 4:55 pm
I talked to Ted Adams from the lindeman archives awhile back and he said that these were only available on the MC.
Post by Lavoy » Thu Dec 24, 2015 9:18 am
Unless you use it a ton, you aren't going to wear them out.
Steven Walters
Post by Steven Walters » Thu Dec 24, 2015 9:29 pm
I have them on a lindeman.
Post by Lavoy » Fri Dec 25, 2015 9:58 am
I think the Lindeman parts manual shows them, but don't have mine near me to check.
lavoy
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sat Dec 26, 2015 7:04 am
Ok, I found my M parts manual and #3 is the snow pad and it lists 12" 28 per track then if you scroll down it says center notch (14 per track)
End notch (14 per track)?
Not sure what this means?
Post by Lavoy » Sat Dec 26, 2015 2:31 pm
Center and end notch are for very very late MC through 440, not the pads you have.
Post by Stan Disbrow » Sat Dec 26, 2015 2:57 pm
Those are the forged snow pads.
This is where the pads alternate having the high section for 1/3 of the total grouser width in the center, or 2/3 of the total grouser width with the high sections for 1/3 on the inner and 1/3 on the outer ends.
Just to confuse everyone, the description in the parts book is for where the grouser is cut down, aka the notch, not where it is high. That would be more logical, no? :P
Since they alternate, there are one-half of the total number required per notch type per rail.
Now, the forged snow pads are something I have seen a lot of, given my 420c (and when I had it, my JD350) has those on it. ;)
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Sat Dec 26, 2015 4:43 pm
Ok, that makes sense now, if they had a picture of the forged pad I probably won't have asked. Lol
Users browsing this forum: No registered users and 237 guests
