test to see if I should try posting
keep getting error messages
Every time someone gets a Debug Mode error, there is a blank post entered. That pushes the post count up and eventually leads to blank pages. What I do is enter on page one, post one, and scroll down to read whatever posts actually made it.
Then, I try for Page 2, and so on, until I hit the No Posts Exist message. Keep posts short. Do not use single or double quotation marks. I have found that both lead to the Debug Mode.
Same as Stan said here
Also when a AN older thread shows up as NEW (with nothing new) I am guessing that someone has tried to post on it and MET MISTER DE-BUG
Stan (and others) try this
keep
the posts small
and go back and edit them
I did this here and so far it has not came up with
DE-BUGGGGGGGGGGGGGGGGGGGGGGGGGGG
GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG
LOOKS like you can EDIT the crap out of it and
NOT MEET MISTER DE-BUG
I edited this like 10 times adding more each time
keep
the posts small
Ah! I had not tried the edit trick. That is better than posting one message in 14 short parts.
I have tried it.
It works. I posted only the above and submitted it. Then, I came back and entered all the rest via edit.
I also entered a new thread in the Board Messages section detailing how this works around De Bug. Then, I discovered that the Message section has no Edit function!
So, the info on the workaround used the other workaround of multiple short posts.
Well, at least this trick works where we need it most.
I have tried it.
Now I am getting errors on short posts.....ok figured that out....
Entering it took me to Page 2 by the post count. But, that is due to too many empty posts, one of which is generated by every Debug Mode attempt.
So, I tried to back up to the main page and reenter this thread. Then, I could see my post since it is really on Page 1. I tried editng, but got Debug Mode.
What worked was closing the browser and starting all over again. Then I could edit and save it successfully.
Sigh
Sigh
Users browsing this forum: No registered users and 253 guests
