Hello everybody,
The sealing rings AT12996T and AT15975T are no longer available. Is there an alternative that I can order in Germany?
The seals belong to the final drive of the 2010 crawler.
Thanks for your help and greatings from germany.
Alternative sealing rings for 2010
- 2010Crawler
- Contact:
Second one (AT15975T) last price DEERE $70 NLA crosses over to a
nat 415458
first AT12996T from JD last price $110 as you said NLA..and NO direct crossover
So you MAY need to reuse (if you can) or need shaft and bore size and thickness to find by size I am sure you wont find one like JD used with 3 dirt seals as shown on this site and post
http://www.yesterdaystractors.com/cgi-b ... s&th=68254
I have to go to work will look by size later for the first one
found the first one
national seal # 416292 CR or SKF # 33073 $30 1/2" wide I would see if i could put 2 in there as the JD one is .750
http://www.oreillyauto.com/site/c/detai ... &ppt=C2389
http://www.oreillyauto.com/site/c/detai ... /N2506.oap
https://www.napaonline.com/en/p/NOS26211?interchange=1
this one looks to NOT have dirt lip
http://www.noc.ua/en/online-catalog-bea ... e=CR+26209
nat 415458
found the first one
- 2010Crawler
- Contact:
Thank you for your help and the links to the sealing rings.
Unfortunately, the axle stub on the sealing surface is so worn that I can not say whether the sealing rings will fit. Perhaps the axle stubs still have to be turned off. I still have a contact in germany, who can perhaps help me out with replacement stakes.
The repair still robs me of the last nerve.
I have bought the 2010 as a ready for use and now follows a repair after another.
Now it takes a bit longer and cost considerably more money.
You seem to have the same problems.
Greetings from Germany
- AussieJD2010
Hi 2010crawler,
I have the same issue as you have mentioned and I have purchased the #33073 seal as my work around. (over a year ago now).
jtrichards comment on installing 2 seals sounds like the best advice and I am going to try and follow that. I am a little bit luckier as one side I can reuse the original seal.
I had a friend turn down my shafts and pressed a new hardened surface, not sure of the metal grade but I can ask if your interested. I should also post some before/after picture of the job.
If you are new to this site and have not had a chance to look around, try to find jtrichards posts as they are a treasure trove of knowledge and will help you calm your nerves
JD2010C Crawler Loader
Remember if you use double seals to pack the cavity between with grease.
Users browsing this forum: No registered users and 136 guests
