after
you edited ..deleted..your posts on my re...trailer post..edited.....i added another message and that went to a valid page 2....i think msg there on pg 2 kinda shows how.
appears whenever anyone gets to debug screen...click BROWSER back to the message screen ..WHERE YOU WROTE THE MESSAGE...and eliminate all but the first word of the msg...SUBMIT that and see if the thing gets past ..debug....then get to msg board post and edit to add the balance of each persons message....be sure to be logged on or you will not even see the edit button in upper right hand corner of your post.... this also enables you to get additional pages
ONCE YOU GET TO THE EDIT BUTTON AND EDIT YOUR MESSAGE YOU CAN ADD THE REST OF YOUR STORY..you DO NOT NEED SEVERAL SHORT POSTS to get story in.
another thing...in effort to eliminate blank pages...as you mite be able to see i have edited this now 4 diff times and have added more lines....
YOU CAN DO THE SAME...JUST LOGGON GET TO YOUR LATEST POST AND ADD THE INFO YOU WANTED TO DISCUSS..YOU CAN EVEN ADD TO THE TITLE WHERE YOU STARTED...THIS WILL SERVE AS INDICATOR AS A CHANGE...IT WILL NOT REGISTER AS A NEW POST AND will not show debug
thanks
dtoots1
stan..more debug info AND MORE INFO 2/8/17
Yes, the post-a-short-one....
....then Edit-the-rest does seem to work.
Now, all I need to do is remember not to use contractions and make a bunch of Debug Mode non existent posts that only serve to run the post count up.
Working on fix I hope, but board might be to old to fix.
your spell checker is automatically putting in your contractions!!!!
so need to spell both words of the contraction....like do not, can not, would not
etc
etc
Users browsing this forum: TheGuise and 86 guests
