Will a inside hydraulic 6 way dozer frame, off a 440IC work on a 1010 crawler?
I believe the model on the dozer frame is a 64
440 to 1010
I did the opposite of you, and it did work, but there is a difference, the blade will hit the grille. Not sure what that means doing the reverse.
Would only work with 12" pads, or 10".
Users browsing this forum: No registered users and 166 guests
