Mc grease and grease guns
I have been reading all the posts about 3 roller grease.. and I want to get it right. I need a low pressure grease gun that fits the button head fittings, and I want to use a thick grease. Correct? Were can I get the grease gun that I need to use? Thanks
Re: Mc grease and grease guns
Gun is irrelevant on an MC, no seals to blow out. High volume will help, you are probably looking at 3 tubes to grease bottom rollers and front idlers.
Thanks, do you guys know what size adapter I need ?
I was going to say 5/8", but that is for the later machines with the bellows seals. The earlier ones are larger, but search as I might, I have not seen a size mentioned anywhere. Only that the older ones are larger. So, looking at mine for a make and model will do you no good.
They changed the size because of the seals and the need for a low pressure gun. Both the gun and the adapter came with a new machine back in the day.
I have them on hand, but should be 5/8".
the 1950 is 7/8 inch fitting
They may have been in 1950, they are not today, and have not been as long as I have been doing this. There are different thread sizes, but all the fittings you will have gotten from Deere in the last 25 years would have been 5/8" end.
Users browsing this forum: Jim B and 97 guests
