hydraulics
hydraulics
Hi everybody and happy holidays! I have a new project , am installing a Thumb to my 420-C loader and am looking for advice as to hose assemblies and if the 420 HYD pump will handle such an addition. Any help is much appreciated, IMO, this is the place for just that
Re: hydraulics
Not a pump issue, thumb should take less flow than main lift cylinders, should work fine.
Re: hydraulics
Thank you Lavoy
Re: hydraulics
I installed a thumb on my Terramite T7 loader bucket. I installed hydraulic quick disconnect couplings to reduce the flow down to 3-4 gallons per minute which works out perfect. I also installed a electrical diverted valve plumbed into the loader curl cylinder, that way I did not have to purchase a additional valve. I just momentarily energized the diverted valve with a push button and the hydraulic flow goes to the thumb instead of the curl. My hydraulic pressure is around 2500 psi. I purchased all of the hydraulic components from surpluscenter.com
Re: hydraulics
That sounds awesome notmeu, would you have any pics/schematics or detailed instrucs that I could look at or download? also will the diverter switch work on a 6 volt sys.?
Re: hydraulics
This is not the exact one that I used but very similar
https://www.surpluscenter.com/Featured- ... 9-8602.axd
There is a tap that shows how it is plumbed into the hydraulics. Being that you have 6volts is a problem. I’m sure there is someone out there that sells the same thing in 6vdc but you will have to do some searching!
Re: hydraulics
Thanks right now I have a starting problem, shut her off two days ago now no spark at coil? any ideas?
Re: hydraulics
Points. Power goes from battery to switch to coil to points to ground. Easy enough to follow even if using just a lightbulb to test. I lose spark, first thing I do is get out the points file and clean the contacts.
Re: hydraulics
Do you have a ballast resistor on the coil? They are usually 3 ohms if my memory is accurate
Users browsing this forum: No registered users and 72 guests
