My jd440ic is running a bit rich....have carbon out exhaust...dang book does not show how or which to turn in etc or how many turns...do i adjust the idle screw...or load screw??? how many turns out??? both my 440 dozer and 40s wheeled running rich...seems to me one of them or both has a little crank handle adjusting screw, whatever one it was i adjusted about a quarter turn and booger spit and sputtered till i turned it back, thought that would make it leaner by turning in?? l anyhow need to adjust em both..
My hearing is shot and no one around here knows how to adjust carbs..., makes fine adjustment a bit of trouble
re..jd440ic marvel slabel carb settings
- Paul Buhler
Re: re..jd440ic marvel slabel carb settings
here's a manual. I hope it helps. The adjustment procedures and jet functions are explained. Paul
http://ntractorclub.com/howtos/pdfs/Ser ... retors.pdf
Good find Paul! I’ve been running a little rich myself... time to clean out those jets!
i added 4 ounce sea foam motor treatment to my full tank of gas...i don't see the black smoke NOW, will see next time i run it. have not messed with jets.
by the way...here it is May 7th and the dozer is still running fine tho i suspect will need to add sea foam again done used it all up...pushing her a bit hard pushing dirt .....pulled large tree stump , pushed 30 tons of asphalt grindings and still going...
Users browsing this forum: No registered users and 124 guests
