Lift cylinder seals..
Jirving43
Post by Jirving43 » Tue Apr 23, 2019 8:05 pm
So both my lift rams were leaking at wiper seal... I replaced the seals and the o-ring.. Both side.. When firing it back up any slowly cycling the cylinders it blew both wiper seal out of the Damn cast iron housing! ... Wtf! Is there a trick to this?... The left side I tapped back in and its fine.. The right side was missing a 1/4 of the plastic ring that lays next to the o-ring in the cast cap.. So it's leaking again.. Worse than before :oops: Lavoy u got that plastic ring?? I can get the seals local there a national 471737.. Get them at any auto parts store.
Re: Lift cylinder seals..
Post by Lavoy » Wed Apr 24, 2019 10:25 am
Not on hand. Check with a local hyd shop, might be a common size.
Jirving43
Post by Jirving43 » Wed Apr 24, 2019 4:48 pm
Can you still get reseal kits for angle and tilt cylinders?
shinnery
Post by shinnery » Wed Apr 24, 2019 10:38 pm
Out of curiosity only, I must have missed the first of this. What size crawler are you working on? Is this a bulldozer blade or a loader? Or????
Post by Lavoy » Thu Apr 25, 2019 8:15 am
Most kits are obsolete, I have been able to piece together the necessary parts in the past.
dtoots1
Post by dtoots1 » Thu Apr 25, 2019 10:19 am
re..jirving machine..
tis a jd440 6 way blade
Users browsing this forum: No registered users and 150 guests
