Lindeman Oil Seals
Lindeman Oil Seals
Interested in speaking with someone who has replaced oil seals between transmission and clutch housing and clutch housing and final drive. Thanks.
Re: Lindeman Oil Seals
You might start with giving Lavoy a call, 701-361-1006
I have not done them, but can't be too difficult. I would assume same process for the most part as the later crawlers. Remove final etc.
Thanks Lavoy, If I have to do the transmission side, do you know if the clutch housing has to be removed to get to the seal?
I'm assuming not, but not positive.
Are you talking about replacing the gasket behind the first gear reduction case? If so, yes the belt pulley and clutch comes off
No, the seal between transmission and steering clutch housing.
Does the housing need to be removed or just the clutch pack?
Users browsing this forum: No registered users and 143 guests
