steering clutch
steering clutch
I have a 1952 MC and am trying to adjust the right side steering clutch. I loosen the lock nut but can't get the lever to slide on the throw out bearing to get the proper free play in the lever. Anybody have any ideas?
Re: steering clutch
You've really posted this in the wrong section, I don't know if someone will see it to move it but you should post it in the early model section it has much more traffic.
JD- 450C track loader
Serial #208336T
Serial #208336T
Re: steering clutch
Most likely rusted tight, not uncommon. Only fix would be to pull the final and clean everything up.
Users browsing this forum: No registered users and 137 guests
