420c hydraulic cylinder Help
Will a lot has happened since my last post I got my 420c out of the hole however I need a hydraulic repair kit for the right side blade. i have gotten it apart and the seals are shot. So do they make a seal kit my serial number is 126086 on the dozer.
Re: 420c hydraulic cylinder Help
I will suggest you send Lavoy an email (postmaster@jdcrawlers.com) and he likely has the parts to seal it in his store. You might do well to send along a couple pictures of your dozer and the cylinder(s) as there were several different dozers used. During those years the blades were attachments and had their own parts catalogs so the dozer serial number doesn't help. Lavoy will likely be able to tell you what model your blade is when he sees pictures.
Users browsing this forum: No registered users and 120 guests
