Deere 820-2010 Loader Backhoe final drive removal. Lots - O -Rust!
fundytides
Re: Deere 820-2010 Loader Backhoe final drive removal. Lots - O -Rust!
Post by fundytides » Tue Jun 28, 2022 9:38 am
You are right Lavoy, it is 1" and the chain had to be shortened. so back to my original questions, what is the best way to remove the pin and can I drive it right on through?
Post by Lavoy » Tue Jun 28, 2022 9:55 am
Yes, it can go either way. There should be a relief in the middle of the pin, so once you have it in about an inch, it will jump to the other side, and then you drive it the last inch. Some heat on the links will help, but not too much so that they bend. If you can get something on the inside to act as a deadman, that will help. I use a giant air hammer called a scaler to pound them out.
Difficult job sometimes if you are doing it alone. As I am almost always doing it alone, in the past, I used a torch, blow the centers out of both ends of the pin, let it cool, and they come right out, then put in new pins. This is the only way I do 350 rails, they are just too much of a pain in the ass to do otherwise.
fundytides
Post by fundytides » Tue Jun 28, 2022 10:35 am
Thanks Lavoy. I think it was only about 10 years ago that I installed this track so the pin shouldn't come out too hard. The only reason I am taking it apart is that the final drive will not release so the clutches probably need some work. Might be in touch with you about these. I did hit the pin using a drift and a small mall and it moved inward about 1/4" so, with a little more force, and maybe a little heat, I think it will go ok
Post by Lavoy » Tue Jun 28, 2022 12:54 pm
If it moved, you've got it made.
jimmydiesel
Post by jimmydiesel » Tue Jun 28, 2022 2:19 pm
This worked well on the 350 chains on my 440. It is an OTC ball joint press.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 604 6 way Blade Carco winch
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
fundytides
Post by fundytides » Tue Jun 28, 2022 6:40 pm
Thanks jimmydiesel. Another good option
iowahill1
Post by iowahill1 » Fri Jul 01, 2022 3:28 pm
Found what I assume to be the master pin. The oblong shape differs from all the round pin heads, and it looks like it's been running loose or free. I can't quite get to the inside to see how it's held but would assume it's a clip of some kind. Anyone know what I should be looking for? Getting access is a challenge at the moment, and a power wash is in order before tackling the removal.
Thanks, -Tom
[img[/img]
1981 Ford 555 Backhoe, 1976 International dump truck, 1950 Dodge dump truck, 1990 Link-Belt LS-4300 CII excavator, , Cat D4 7U dozer, John Deere 820/2010 track loader backhoe
"Not knowing what I'm doing has never been a deterrent!"
original possum
Post by original possum » Fri Jul 01, 2022 3:42 pm
Should be a snap ring that can be a bear to remove the first time. Unless you have an outer snap ring tool for snap rings without holes the best I've found is two screwdrivers of the same width turned in opposite directions.
iowahill1
Post by iowahill1 » Fri Jul 01, 2022 3:51 pm
Thanks, now I know what to feel for. The track cannot be moved and the master is at the bottom. I've slacked off the track adjuster to get as much play in the rail as I can, but pad removal isn't going to be easy due to limited available clearance. I have all kinds of snap ring tools, so once I get it clean and better access to the inside of the rail I might be able to wrangle it out. BTW, where can I get new bolts for the pads? Never had to search for them before. -Tom
fundytides
Post by fundytides » Fri Jul 01, 2022 4:12 pm
I've always used Fastenall. My opinion is regular bolts and lock nuts. Others may disagree.
iowahill1
Post by iowahill1 » Fri Jul 01, 2022 4:21 pm
I've seen "plow bolts" mentioned before and thought that maybe the alloy was better suited for high abrasion applications. The heads on my pads are low profile. I buy from Fastenal and will check them out if and when need, which may be sooner than later! My pads look pretty sad but getting the final drive and clutch freed up is the priority at the moment. -Tom
fundytides
Post by fundytides » Fri Jul 01, 2022 4:47 pm
Not sure about your machine, but my old 40c does not take plow bolts which are a different profile altogether from a regular bolt. If in doubt, ask Lavoy what he recommends.
iowahill1
Post by iowahill1 » Sat Jul 02, 2022 8:50 am
Am I correct in assuming you went with Grade 8 hardware? -Tom
fundytides
Post by fundytides » Sat Jul 02, 2022 10:28 am
fundytides
Post by fundytides » Sat Jul 02, 2022 10:30 am
No, I used Grade 5. Others can chime in if I am wrong but I think the theory is that it is better for the fasteners to wear than the shoes.
Users browsing this forum: No registered users and 109 guests
