This set up is not the one pictured in my manual. What's the adjustment procedure for this set up?
Okay, can't get the pic to transfer to the forum. What am I not doing right. It's on my desktop, is there trick to posting it here?
1010 steering clutch adjustment
40C, 420C, 1010C-L-BH, Cat D4
Re: 1010 steering clutch adjustment
Are you using a 1010 manual?
Pics must be hosted by a third party hosting service.
Yes 1010 manual that refers to a unit with 2 lock nuts and a hexagon center piece IIRC. What I have is a unit with one lock nut and a spring wound centerpiece. It looks almost like some sort of automatic adjuster. I'll try putting the pic on a different thingy on the 'puter.
That is the 350 replacement adjuster. Slide the spring loaded piece back, lift it off the ball, adjust, and reinstall.
No problem.
Users browsing this forum: Google [Bot] and 70 guests
