So i am restoring a 440 wheel tractor and have it down to the bare bones , i popped trans cover off to replace shift lever and found a moderate ammount of rust and debris on the top gear cluster . This thing sat outside for numerous years .
Has anyone had luck with a wire brush and cleaners or acid or any other ideas ?
Mark
440 transmission rust
Re: 440 transmission rust
Well I wound up getting most all of the rust removed and flushed out of housing .
Now on to removing shift lever out of cover , how is a guy supposed to remove that stubborn pin ? Any tricks out there ...
The pin is not the retainer if that is what you are assuming. The snap ring holds the "bearing" in place, which holds the shifter in place.
I managed to tap the shifter out from the inside of plate , 60 years of scale rust it was hard to figure out how it was put together .
But there is no bearing as manual shows and clip was found what was left of it .
I should have bearing kit on hand.
Users browsing this forum: No registered users and 88 guests
