Vacuum tips and tricks for a better cleaning experience
A good vacuum cleaner can help you a long way in keeping your house spotless. But do you know you can also help your vacuum works less burden? Try these tips below for a better cleaning experience with your trusted vacuum.
1. Keep dirt source at the lowest limit
One way to make your cleaning process go faster is to keep your house from getting too dirty. A common source of dirt is from your shoes. No shoe inside policy helps a lot on that aspect. Your shoes carry dirt from outside into your house and spread them everywhere you go. This can leads to more work for your vacuum. Even the best vacuum cleaners in the world will worn-out quickly due to cleaning too much. If you don’t feel comfortable walking around your house with socks or barefoot, you can at least put a mat to wipe your shoes before entering the house.
2. Dusting around the house before vacuuming
Although there are crevice tool and other attachments to help you clean surfaces, it’s best to give those areas a nice dusting session before vacuuming. When all the dust is stirred and sits on the ground, they’re easier to collect. Dusting first gives you the advantage of vacuuming once. If you do the other way around, you may have to vacuum again after dusting. No one likes that kind of hard work.
3. Use your hepa filter in the most effective way
The hepa filter indeed helps you eliminate allergens and dust during vacuuming. Still, you can also use it to freshen the room afterward. All top vacuum cleaners have hepa filters, so this trick is quite easy to do if you have the right product. After vacuuming, you should leave the vacuum on for some extra minutes. The hepa filter will freshen your room even more.
Important Site: Best Vacuum Cleaners
4. Remember your vacuum’s setting options
The idea of having a vacuum that can go all-terrace is tempting. But they’re not yet smart enough to switch between different surfaces. So it’s up to you to choose the right setting for the right area. Top rated vacuums come with various settings, don’t let them go to waste! These features exist to give you a better cleaning experience. Remember to make the most of them.
5. Hit me baby one more time
Or several times! No matter how strong your vacuum’s suction power is, some areas require deeper cleaning by vacuuming them multiple times. When doing so, you should also go in different directions for the best result. This trick is most affected for carpets, because they tend to trap dirt among fibers and need a particular method to separate them. Don’t rely too much on the title of the s. How sufficient a tool can get best vacuum cleaners on the market stly depends on the way the user uses it.
Find these tips and tricks useful? Apply them in your cleaning session, and don’t forget to share them with others who can be benefited from them.
Need an Gressen OEM VALVE
Users browsing this forum: TheGuise and 125 guests
