I have a question about a 440ic carburetor that I hope someone can answer:
Should the pressure relief valve be positioned in the upper or lower half of the choke valve?
While rebuilding my tsx756 carburetor, I removed both the throttle and choke valve plates before reading SM-2024, where it recommends making note of the position of both before removal...
Thanks,
Roger
TSX-756 Choke Valve Position
- Roger440IC
440-IC
420-U
420-U
Re: TSX-756 Choke Valve Position
If the choke is on, the flap should be able to open to let a little air in, so if it makes sense, the flap is downstream relative to airflow.
- Roger440IC
Thanks Lavoy, that makes sense.
Should the flap be positioned above the choke shaft or below it?
Roger
Roger
440-IC
420-U
420-U
Below.
- Roger440IC
Users browsing this forum: No registered users and 158 guests
