I am looking for a 440 gas tank or any idea's to rig something up, also can't seem to find a rebuild kit for the carb. Can anyone help?
I just cleaned up the entire motor, cleaned carb, changed oil, replaced fuel lines and filters, put it back together and tried to fire it up with a 12 volt battery. For being a 6volt system I would have the thought the starter would have turned the motor over fast. However, the jumper cables seemed to get hot and the engine just barely turned over, do you think the starter is shot? I seemed to have a good connection with my cables and I could turn the motor by turning the fan by hand. I gave up as the day was getting late and the carb was leaking fuel from a worn out gasket. Anyone offer any suggestions?
Thanks in advance,
Ironyetty
440 IC PARTS
- switchhappy
If the battery in your crawler is flat and the jumper cables are carring the whole load they probably are not heavy enough even using 12volts....most jumper cables any more are only 6 gage and if you are lucky they mightt be 4 gage. not heavy enough to carry the whole load.....you would be better off to put a fresh battery in the crawler and go from there. Check the starter if it has been laying up for some time the critters may have moved in lol dosen[t hurt to clean it up also.
just a guess
Bill
just a guess
Bill
Bill 420c dozer 5 roller
N. E. Alabama
older is better just keep it greased
N. E. Alabama
Users browsing this forum: No registered users and 112 guests
