420C front idler size difference
Just started a "time to fix" stuff on my 1957 420C. Front idlers are rough and I acquired a set theoretically off same vintage 420. When I removed mine and placed side by side I noticed a difference. Mine are 21" in diameter and replacements are 19" in diameter. Did JD make different size idlers for the 420? As I have minimal adjustment left ( 1-1 1/2") this could be a problem.
Re: 420C front idler size difference
I believe the 19" were standard and the 21" (oversize) were an option. The larger idlers use one additional pad in the belt.
Thanks Mike, going to count pads and see where I am at.
4 roller with standard idler uses 31 links per crawler belt
4 roller with oversize idler uses 32 links per crawler belt
5 roller with standard oversized idler uses 35 links per crawler belt
jerry
Good- to see another "wisconsinite" with a 420 crawler!!
jerry
Yup,
32 pads, so they are the "optional" ones. Did find something strange on the right ideler, the axel is a two part set up with a "supposed to be" solid inner axel, its snapped in half where there was a pin through it which tied it to the large bore cylinder which rode on the bushings. I have three other front ideler axels which are all one solid machined unit,,,somebody been there? or was this a factory replacement? I think that axel is kinda wierd, if I can figure out how to post a pic will do.
Going to have to rebush everything, when that axel snapped it tore up the entire assembly. Hope Levoy has bushings.
Mike, I up on the MI/WI border, where are you close to?
I should have bushings on hand, if not, short delay.
Levoy thats great, would you have the seals (AM 2011 T) on hand also?
going to be more, getting a list going. will contact you soon.
Users browsing this forum: No registered users and 144 guests
