Rebuilding fuel shutoff valve?
JD 420c, out of fuel after sitting a bit. Filled it up & there was a big dribble out of the shutoff valve, despite it being off. Pulled the whole fuel bow assembly then the shutoff valve. I can't figure out how to pull off the packing nut to get to the O-ring that I assume is leaking. Is the only way to grind off the end of the fuel shutoff knob or the shaft that it's on?
1956 JD 420c crawler loader
2016 Kubota L4060hstc
Re: Rebuilding fuel shutoff valve?
They are not rebuildable.
Thanks, hopefully the $15 one off Amazon isn't junk.
Users browsing this forum: No registered users and 148 guests
