1959 440 ic track rollers
got the track back on .but i better change the rollers theyre #m2233t any ideas where i can find them?Tod
jd 440 ic crawler i need parts when i break it.
They're not made anymore. Murphy Tractor sells the 350 rollers on eBay with the 1/2" mounting holes for $135 a pop plus shipping. I'm sure Lavoy can help you out too. Lavoy, these would work on a 440 wouldn't they? Just not authentic.
http://cgi.ebay.com/John-Deere-350-B-C- ... dZViewItem
440 track rollers
wwattson wrote:They're not made anymore. Murphy Tractor sells the 350 rollers on eBay with the 1/2" mounting holes for $135 a pop plus shipping. I'm sure Lavoy can help you out too. Lavoy, these would work on a 440 wouldn't they? Just not authentic.
thanks ive been looking all night .and you were the unly one to reply. the price is kinda steep i have sees used ones for less but ive got to get er goin and i certianly dont want to get back in the moat and then throw a track again .thought i might try the forum .lavoy is great last week it was the hyd pump and he had one and got it out pronto .only to find out on my behalf that the shaft coupler was worn out .i had to weld it solid after taking the pump off 5 times. hey does anyone need a hydraulic pump ?maybe i should keep it for spare or just hold on to it.thanks lavoy, i looked for that pump for a week before i found one and you were great assistance on the phone...Tod
You say you can weld? I rebuilt my ground rollers, not much to them.
I just cut out some plate and put the lip back on or built the edges back up with weld and ground smooth. Just make sure the width and depth are right so you don't have any track wear from them.
Another option ,if Lavoy doesn't carry any is Roberts Equipment (http://www.robertstractor.com/),
Crawler Heaven (http://www.crawlerheaven.com/index.htm), you should be able to get them for $60 to $80 used.
Ironyetty
Ironyetty
Users browsing this forum: Bing [Bot] and 141 guests
