40C charging
40C charging
What should my 40 be charging? I am getting 11+ volts. Is that right for a 6 volt system?
Till All Are One
- JD440ICD2006
I am thinking that a 6 V generator was only going to put out around 8+. Check to see if it is a 6 V or maybe has been switched to a 12 V.
I know that it is a 6 volt system. It starts like a 6 volt and the dead give away is the 6 volt battery. Would having it charge that high make it run bad? I have tons of power but every so often, say every 10 minutes or so it craps out and dies , after I let it sit for 20 minutes it starts up and goes fine. It used to start right up after dying but now its not keeping a charge and I have to hand start it, hence the 20 minute wait. I have to admit it sure starts easy by hand when its cold, 1st crank every time.
At first I thought it was old and dirty fuel. I drained the old fuel and figured that it would pass what was in the carb.
Let me know what you think.
Till All Are One
- JD440ICD2006
I have never seen a 6 V generator put out 11+ volts. That one baffles me.
As for shutting down, chances are there is something still in the tank that finds it's way to the inlet after running, thus shutting off the fuel.
Keep us posted.
What is funny is sometimes we end up fixing them and are not really sure what we did to fix it.
Keep us posted.
- DiggerLarry
- Contact:
Replace your V. Reg. It should be no more than 7.5 volts for a 6v system.
That should also fix your shutting down problem. 11 volts puts too much current thru the coil overheating it, causes loss of spark, engine dies. Cools down after 20 minutes or so and will start back up again. May also need to replace coil and points as the heat will damage them.
1963 John Deere 2010C, Diesel, 6 way PAT Dozer
1950? John Deere MC
1952 Ford 8N
1950 Ford 8N with Sherman over/under drive and homemade Backhoe & Loader
Did have a 1956 IH TD-9 Drott Skid-Shovel, "Smokey"
1950? John Deere MC
1952 Ford 8N
Users browsing this forum: TheGuise and 62 guests
