Post
by NNAATZ » Mon Oct 15, 2007 8:05 am
i pulled a drive becouse of another leaking seal on the drive, i pulled the clutches and found the steels to be vary rusty witch was suprising becouse it's used often. can i polish them with a DA sander or die grinder with a scotch brite wheel or sand blast them lightly, being carefull not to take to much material, how thick should they be? all fibers are in spec. should i be looking at new ones?
thanks nick
Post
by mini kahuna » Mon Oct 15, 2007 8:34 am
I would replace the discs "both fiber and steel" because pulling off finals is not my idea of fun,pressure plate,throwout bearing and brake band too.
do it all one time and you won't have to go back in there for years.
1010 loader
Post
by NNAATZ » Tue Oct 16, 2007 10:35 am
i think i will replace the clutches anyway, every thing else had been replaced by the the previous owner(s).
Post
by mini kahuna » Tue Oct 16, 2007 11:13 am
I am amazed how many people go threw the trouble of pulling a final off and don't replace everything,you have the right idea,replace the discs both steel and fiber and be done with it,make sure that brake band is right too"no oil or rusty".
1010 loader
Post
by NNAATZ » Tue Oct 16, 2007 3:40 pm
there on there way, and a gauge too set the plate
thanks again Lavoy
Post
by mini kahuna » Tue Oct 16, 2007 4:41 pm
awesome,you'll be all set on that side for years to come,good job!!
1010 loader
Post
by NNAATZ » Tue Oct 16, 2007 5:37 pm
i have all ready been thinking of that!!!!...... doing the other side
Post
by mini kahuna » Wed Oct 17, 2007 7:50 am
don't jinx yourself.
1010 loader
Post
by NNAATZ » Wed Oct 17, 2007 8:31 am
i will take it easy for while, it won't know what to think with new parts threw at it
