Hey all,
What makes the floats collapse in on these Marvel-Schebler carbs?
If they are dry and not leaking and only slightly concave on one side do they still exert as much pressure on the fuel shutoff needle? Is this a reason for the fuel leakdown problem or are they by design not boyant enough to keep the needle valve closed tight enough on the seat?
Chuck
carburator floats
carburator floats
Awhile back I came across an explanation someone had given for this....brass floats will be collapsed if water accumulates in the float bowl and freezes. It takes quite a bit of water to do this but apparently it does happen. The ice expands and pushes upwards against the float which it can`t go any higher so it collapses.
Users browsing this forum: No registered users and 149 guests
